I am selling a used Nortek DVL 1000. It comes with the testing cable for Ethernet and serial, as well as a dummy plug to protect the connectors. We have a new DVL and no longer need this, so I figured someone can make more use of it rather then it sitting on a shelf.
This unit has been tested and is in full working order.
There is some slight corrosion on the RS422 Tx+ pin, it can be seen in the photos. However it is still able to transmit and receive over RS422 fine! RS232 is unaffected, and the ethernet connector is like new.
Both of the connectors are MacArtney Subconn MCBH8M.
Main Specifications:
Frequency: 1 MHz
Bottom Track Range: 0.1 m to 75 m
Velocity Resolution: 0.01 mm/s
Long-Term Accuracy: ±0.1% / ±0.1 cm/s
Depth Rating: 300m
Condition: Used - Tested and Fully Functional
Location / Shipping: Located in Canada (Alberta), I will package it and ship it wherever you like however shipping cost is your responsibility. Based on some rough estimates, shipping to San Diego, as an example, is roughly $350-500. Depending on location as well (anywhere except US) we will have to apply for an export license which can take 15-40 business days to review. However is you are in the US this is not necessary
I have a lot of photos and videos of the state/status of the DVL.
Hi there, so sorry for the delay, I never got notified of a response!
All Nortek DVL 1000s do not have an INS. The Nortek Nucleus 1000 DVL does however.
Just to clarify, I am the seller and am in Alberta. And the shipping paperwork would mainly be handled by myself, but some things will need the buyers information, signature, etc, since this is a dual-use product. The carrier will likely be UPS or FedEx or similar.That estimate I gave in the listing was with UPS.
And on the RS232 side, I don’t have a RS232 adapter (the person who did is not here anymore) so I am currently making a small crude one, and should have it done soon. I will upload some more photos to the google drive once it is working and update here as well.
I should have mentioned this in the listing as well, but the bulkhead/connector is just a product you can buy from MacArtney, so you could replace it if you’d like. I do not know the price for the male version on the unit, but the female version (MCBH8F) was roughly ~160 last time I checked, and are presumably similar prices.
I have tested the serial connection for both RS232 AND RS422 and both are working completely fine! I have uploaded test videos in the google drive link in the listing.
Also after testing, it seems the pin out I was looking at originally was incorrect, the corroded pin is actually the RS422 Tx+ pin, not the power pin. However that still does not effect anything since it was able to transmit and receive over RS422 fine! And it doesn’t effect RS232 at all!
It doesn’t seem like I am able to edit the post to reflect this.
I’ve edited it for you to reflect the update
If I’m remembering correctly posts have an edit timeout for normal users, to avoid confusion from changing history.
