# Flashing Firmware
**URL:** <https://discuss.bluerobotics.com/t/flashing-firmware/11555>\
**Category:** Ping Sonar Devices\
**Created:** [February 14, 2022, 3:27pm UTC](https://discuss.bluerobotics.com/t/flashing-firmware/11555 "2022-02-14T15:27:40Z")\
**Showing post:** 2
**Post date:** [February 14, 2022, 10:17pm UTC](https://discuss.bluerobotics.com/t/flashing-firmware/11555/2 "2022-02-14T22:17:08Z")
Hi @Alex3, welcome to the forum 🙂
> [@Alex3](#):
> I am trying to flash my ping sonar down from V3.28 to V3.27\_9600b in order to use the Arduino code over 9600 baud rate (as I have other Serial components which run on 9600).
> [@Why is updating firmware so complicated?](https://discuss.bluerobotics.com/t/why-is-updating-firmware-so-complicated/11549/2):
> we’ve just released an update to the `ping-arduino` library …, so that it’s now able to work properly with the `3.28_auto` firmware instead of needing to downgrade it.
You should be able to install the latest version from the Arduino Library Manager 🙂
> [@Alex3](#):
> I’ve followed the instructions [Firmware Update - Ping Viewer](https://docs.bluerobotics.com/ping-viewer/firmware-update/) but when I click ‘Firmware Update’ the page freezes and doesn’t change/restart again.
This is a known issue that should be fixed in the latest version of Ping Viewer (which we’ve just released). You can download that from [here](https://github.com/bluerobotics/ping-viewer/releases) or [the installation docs](https://docs.bluerobotics.com/ping-viewer/), although you shouldn’t need to downgrade the firmware anymore (it’s better to update `ping-arduino` instead) 🙂
> [@Alex3](#):
> I have had this working with the Arduino example using 115200 baud rate.
As per our updated [guide](https://bluerobotics.com/learn/using-the-ping-sonar-with-an-arduino/#firmware-version-and-baud-rate):
> [@Using the Ping Sonar with and Arduino - Firmware Version and Baud Rate](#):
> For flexibility, our ping-arduino example uses SoftwareSerial, which communicates with Ping at 9600 baud\*.
> If your microcontroller has an extra hardware serial port, you may use that instead at 115200 baud.
> > \*&nbsp;SoftwareSerial _may_ connect at 115200 baud, but behaviour and performance can be inconsistent, so it’s not recommended.
_[View the full topic](https://discuss.bluerobotics.com/t/flashing-firmware/11555)._
