# Fathom Spool Slip Ring Specs
**URL:** <https://discuss.bluerobotics.com/t/fathom-spool-slip-ring-specs/12252>\
**Created:** [June 3, 2022, 4:24am UTC](https://discuss.bluerobotics.com/t/fathom-spool-slip-ring-specs/12252 "2022-06-03T04:24:22Z")\
**Showing post:** 2
**Post date:** [June 3, 2022, 7:37am UTC](https://discuss.bluerobotics.com/t/fathom-spool-slip-ring-specs/12252/2 "2022-06-03T07:37:26Z")
Hi @spotxuv,
> [@spotxuv](#):
> Are there any specs (drawings/model number) available on the slip ring used in the spool?
I don’t have access to this, so I’ve asked internally whether it’s something we’re able to share.
> [@spotxuv](#):
> I saw another thread suggesting it had a 1.5A current rating
I assume you’re referring to this:
> [@What are the slip ring specs](https://discuss.bluerobotics.com/t/what-are-the-slip-ring-specs/5317/2):
> though the slip ring itself is rated for 240 V by our supplier, we have not designed the Fathom Spool/slip ring assembly as a whole to take anywhere near this voltage. We strongly dissuade anyone from using either of these components/products with high voltage, they have not been designed for this and have not undergone any necessary high voltage testing. The slip ring is also rated at 1.5 A per circuit by our supplier, but we have not yet verified this ourselves.
> [@spotxuv](#):
> I’m looking for a drop-in replacement with a higher current rating (and replace the Binder plugs as well).
@BlueLink_JC seem to have posted about something like that [here](https://discuss.bluerobotics.com/t/new-high-voltage-slip-ring-for-fathom-spool/9245), if that’s of interest 🙂
_[View the full topic](https://discuss.bluerobotics.com/t/fathom-spool-slip-ring-specs/12252)._
