Extension "ghosting" and not allowing uninstall
I am running the newest beta branch OS (1.5.0-beta.43) resetting the core docker isn’t working
While trying to install the Ros2 extension and it has seemingly become stuck in limbo.
From some googling I have found refrence that it might have been because I had bad connection while installing it bug: kraken register extensions that fail to be downloaded (github bug report 2025). What are the actual steps to remove the empty extension to allow me to remove it as a element/allow me to try to reinstall the extension the official way?
Any help is welcome! I’ll likely just build the plugin locally on the pi through ssh and then manually installing it from the archive. But it’s probably not good to leave the “ghost” extension hanging since the system probably is trying to reboot it occasionally
The yellow heartbeat is because the 64bit os is fresh and the compass needs to be calibrated.
Edit: cleaned the post a bit.
And the UI element preventing reinstalling the extension seems to have gone away by letting the device be for a night. So it’s possible that maybe it was some kind of website caching or a proper full reboot would have fixed things? Though I did prune the docker images on the pi yesterday. So I don’t know hopefully no one else runs in to this annoyance.
Okay, I ran in to it again. (The extensions page not allowing starting/stopping/restarting/uninstalling, because the installed extensions list isn’t updating)
Seemingly clearing the browser cookies does remove the mismatched state that prevents you from interacting with the extensions through the browser based interface. Though I don’t know what exactly causes it, so it might just be one of those 64bit system version problems that were alluded to?
