Hi everyone,
I’m an Italian geologist using my self-built bathymetric USV, equipped with Blue Robotics components.
My current system works well for manually controlled bathymetric surveys, but I would like to upgrade it with autonomous navigation and real-time survey monitoring, reusing as much of my existing hardware as possible.
Current hardware:
Raspberry Pi 4 with Blue Robotics Navigator and BlueOS.
Blue Robotics Ping1D echosounder.
TOPGNSS TOP609BT dual-frequency RTK GNSS receiver, connected via USB.
RTK corrections via Hexagon SmartNet FullGNSS NTRIP, already configured and working in BlueOS.
Hitec Aurora 9 transmitter and Optima 7 receiver.
Single electric motor with ESC and servo-controlled rudder.
Separate power supplies: 5 V power bank for onboard electronics and 5S 10 Ah LiPo battery for propulsion and RC equipment.
Currently, I manually steer the boat while logging RTK GNSS coordinates and Ping1D depth measurements, downloading the recorded data after each survey.
What I would like to achieve:
Autonomous survey navigation: Generate and follow parallel bathymetric survey lines with adjustable spacing and speed.
Real-time monitoring: Display planned survey lines, the actual track already covered and current vessel position on a laptop or Android device on shore, to identify any missed areas or deviations.
Manual/automatic control: Retain my Hitec Aurora 9 and Optima 7 to switch easily between autonomous and manual navigation, while keeping bathymetric logging active.
My main questions are:
Can I implement these functions using my existing Navigator and Raspberry Pi 4 with ArduRover, sharing the RTK GNSS positioning data already available in BlueOS?
Which software would you recommend for mission planning and live track visualization: Cockpit, Mission Planner, QGroundControl or something else?
What additional hardware or interfaces would be needed to connect my existing RC receiver, ESC and rudder servo to Navigator?
What would be the simplest, most affordable wireless solution for monitoring the mission from shore?
I’m looking for a practical, low-cost upgrade, preferably using open-source software and compatible third-party components where appropriate, without replacing my existing GNSS, sonar or other working equipment.
Any suggestions, examples of similar USV projects or setup guides would be greatly appreciated!
Thanks in advance!
Federico
