I’ve just acquired a BlueRov2 and an Oculus scaner. I’ve installed them and tried them, but I am somewhat confused:
I am using Cockpit, connecting directly to the ROV. However, I read that there is another piece of software that I may use: qgroundcontrol. Do I have to install them both? Cockpit actually includes qgroundcontrol?
I can have both software programs open, BROV2 Cockpit and Oculus Viewpoint. But when Viewpoint is active, Cockpit freezes, and I lose control of the ROV. Evidently, something is wrong.
I would need to work under stronger currents than the BROV2 can handle. Has anyone had experience guiding the ROV with a guideline or another method?
Hi @jeabramian -
Welcome to the forums!
In answer to your questions:
QGround Control is software that Blue Robotics originally recommended the use of for controlling the BlueROV2. Since developing Cockpit, we recently changed our documentation to only target this newer and more flexible software! Use of QGC is not recommended…
Are you using Cockpit lite in the browser as a BlueOS extension? If so, install the full standalone version. A limitation of the light version is inherent to the browser - if the window is not in focus, then it loses connection to the joystick which disconnects control of the vehicle.
When contending with strong currents, you have a few options.
The horizontal thrusters on the vehicle can be mounted at a 30 degree, instead of 45 degree angle, giving you more forward thrust.
A slim tether has significantly less drag, but can only be used in shorter 200m (vs 300m) lengths.
Finally, a clump weight attached to the tether directly, 5-10m from the vehicle, lets the mass passively overcome the current - this does require you to lower the weight down from directly over your target dive location.
I’m not sure what you mean by “guideline” but when descending to targets, I have used a clump weight on an anchored line to “zipline” the ROV down to the target.
Thanks Tony! your answer clears a lot of doubts I had. By guide line I, was thinking of a Downline / Guidewire a rope with a heavy weight that I could keep more or less tense and to which I could attach the ROV. I guess is something similar to what you are suggesting, I guess. Do you have any pictures by any chance?
Thanks a lot!
Hi @jeabramian -
I don’t have any pictures that illustrate it, but this video captures the descent and capture of the seaweed array. If you download the associated subtitles file and play with VLC, and both in the same directory, you can see telemetry including the impressive 170m + depths achieved!
For context -
First the subsea target was captured by positioning a horizontal line upcurrent of the structure, it hung up on the object and was pulled tight and attached to floats, and served as a mooring for the boat (despite using thin Dacron line.) This was sufficient to guide the ROV, but not lift the object.
A heavy weight was attached to buoyant rope, and loose zip ties attached to this downline. About 10m of rope went from this attachment point to a large hook with spring-gate, held in the jaws of a Newton gripper.
The weight was lowered, dragging the large lifting rope and ROV down with it - the ROV would not have had sufficient power to overcome the buoyancy and drag of the large line, and twisting the tether and line together would have been hard to avoid.
The carabiner was attached to the system, and then released by the gripper - skillfull piloting begins around 21:10. A previous capture had a carabine lock closed around a lift point - on this occasion the gate didn’t quite close due to the size of the rope targeted! The ROV was piloted clear of any lines, and the operation to capture the system was a success.
This is an excerpt of an ongoing recovery operation - unfortunately the seaweed array is still stuck at depth! When things are resolved successfully, we plan to release a long-form, podcast-like video reviewing this and considerable additional footage!
