Having question again. I manage to operate the BlueROV2 Heav Config. But I need to connect to internet while using it.
Now Im having area where internet not available and I want to use the cockpit stand alone. I tried to follow the documentation (Screenshot below) seems not success to me. Is there any link or video tutorial how to setup that
Using Cockpit or Cockpit light doesn’t require internet! The standalone version can be downloaded and installed from github, and is linked in the Cockpit documentation.
Once installed, on the general config page you show, change the vehicle network connection (global address) to 192.168.2.2, the default IP address of the vehicle. Cockpit will connect, and if you select your typical user profile under User Settings, all your configurations will load up as well!
Your control computer’s WiFi can be used to access the internet, while controlling the vehicle over the ethernet connection to the .2.X network.
I think that’s what you’re asking? Hope you get things working as you’d like!
