Home        Store        Learn        Blog
Boat power options
I have a friend who is making me a boat which I plan to use for remote missions near the coast line.
The boat is the following one: boat (1) — Postimages
I wonder if it is enough to use a T200 Thruster to power the boat along with a rudder to have steering control of the boat.
My plan is to use 6s LiPo but I can go to 5s or 4s if necessary. I do not intend to have a speedy boat, just cruising around at let’s say 10mph max.
Thank you and best regards,
João Fonseca
Hi @JF2021, welcome to the forum :slight_smile:
Max speed depends a lot on the mass being accelerated, and the surface and drag area of the boat. As a very rough reference, this post discusses using two T200 thrusters to propel a human diver underwater (using our 4S6P battery), and ends up with an estimated max speed of about 43m/min, which is ~1.6mph.
Presumably your boat will have a decent amount less drag than a human diver, since it’s smoother, partially out of the water, smaller, and doesn’t need oxygen tubes and the like. I would also guess a remote control boat of this size would be lighter than a human (and perhaps quite significantly so), but that depends what you put in it and make it out of.
Without knowing more about the boat properties it’s difficult to give a meaningful max speed estimate. My intuition tells me you’re unlikely to get 10mph with a single T200, but may do with two or three. Then again, I don’t have much experience with boats so I have very little trust in my intuition here, particularly given the lack of important parameter details :slight_smile:
As per the T200 Product Page they’re rated to use 7-20V, and we don’t recommend going above that without power limiting, so if you want to use 6S you’ll need to be quite careful with how you set up your throttle control.
