Hi everyone,
I’m looking for some advice from anyone who has experience integrating SIYI systems (MK32/HM30, MK15, etc.) with a BlueBoat running BlueOS. E.g.: SIYI MK32 Enterprise Handheld Ground Station Smart Controller with 7 Inch HD High Brightness LCD Touchscreen Dual Full HD Digital Image Transmission 4G RAM 64G ROM Android OS for UAV UGV USV 15KM Range CE FCC
My goal is to move away from carrying a laptop+base station and instead use a dedicated handheld controller for day-to-day operations.
For context, typically, I don’t operate offshore. Most of my work is on inland lakes and rivers, often in areas with many obstacles, vegetation, narrow passages and limited access. Because of this, compactness is very important—I’d really like to avoid carrying a laptop and instead have everything I need in a single handheld controller. Manual control is also important, as I frequently need to maneuver precisely around obstacles rather than relying solely on autonomous missions.
I’m not looking for extreme range. A reliable 1–2 km communication link would be enough if it allows me to operate manually, run missions, and access BlueOS when needed.
Ideally, I would like to:
- Control the boat manually using the controller.
- Run QGroundControl on the controller for mission planning and autonomous missions.
- Access the BlueOS web interface directly from the controller’s browser (to configure payloads, check system status, etc.).
- Iif possible, forward NTRIP corrections from the controller (connected to my phone’s hotspot) to the boat.
From what I’ve found, the HM30 air unit appears to support Ethernet/network communication in addition to MAVLink, but I haven’t found a real-world example where someone accesses BlueOS over the HM30 link.
So my questions are:
- Has anyone successfully integrated a SIYI MK32/MK15 (HM30) with BlueBoat and BlueOS?
- Does the HM30 provide a transparent enough IP connection for normal BlueOS operation (browser, extensions, SSH, etc.), or is it limited to MAVLink/video?
- Is Internet sharing from the controller to the onboard Raspberry Pi possible (for example, to provide NTRIP corrections)?
- What real-world communication range are you seeing over water with the standard HM30 antennas mounted on a BlueBoat?
Perhaps it is a overkill, and a 4G modem onboard is sufficient. If the latency is low enough for confident manual maneuvering, maybe that’s the more practical solution for most of the cases. However, I’d prefer not to depend on cellular coverage. I often work in remote inland locations where coverage can be unreliable or unavailable, so having a communication system that works independently is a major advantage for me.
I’d really appreciate hearing from anyone who has tried this setup—or has gone down a similar path with BlueBoat. Any real-world experience, recommendations, or alternative approaches would be greatly appreciated.
