I am trying to interface a Blue Robotics Bar30 (MS5837-30BA) to an embedded Linux RFSoC platform using an FTDI C232HM-EDHSL-0 (FT232H) cable and PyFtdi 0.57.2.
Configuration:
FTDI C232HM-EDHSL-0
PyFtdi 0.57.2
I²C frequency: 100 kHz
Orange → SCL
Yellow + Green tied together → SDA
Red → VIN (4.98 V measured)
Black → GND
I added two 4.7 kΩ pull-up resistors to a 3.3V power rail.
SDA → 4.7 kΩ → 3.3V
SCL → 4.7 kΩ → 3.3V
I get:
Write ACK: True
Read ACK : True
Reset ACKed
However, all PROM coefficients return zero:
0xA0 = 0x0000
0xA2 = 0x0000
ADC conversion reads are also:
D1 = 000000
D2 = 000000
Has anyone successfully used a Bar30/MS5837 with an FT232H/PyFtdi interface?
Hi @rajithapalipana -
Welcome to the forums!
Blue Robotics has not tested that particular adapter. I would guess that it has significant wire length between the I2C chip and the wiring splice is significant - and given the standard wire length on the Bar30 is about at the max length most systems can typically communicate at, your overall wire length may be causing issues!
Additionally, you have pull ups to a 3.3V supply, but that chip may communicate at 5V TTL levels, which would permanently damage the Bar30…
For the D1/D2 zeros specifically, how long are you waiting between sending the conversion command and the 0x00 ADC read? The MS5837 datasheet says if the ADC read is sent while a conversion is still running, the result is 0, and at OSR 8192 the conversion can take up to about 18 ms (around 2.3 ms max at OSR 1024). That wouldn’t explain the PROM reads coming back as zero though, so it might be worth checking whether the PROM read is being done as a write of the command byte followed by a separate 2 byte read, rather than a combined transaction.
