I am in the process of building an ROV that will be rated to about 1000m depth, and i am in the process of buying a custom, neutrally buoyant fiber optic tether from alibaba. Its going to have 2 fiber optic strands, aramid yarn, a foamed buoyancy layer, water blocking yarn with the aramid, and an external TPU jacket. I was wondering whether a wetlink M10 - 5.5 mm - HC - 5.0 mm ± 0.3 mm penetrator is alright for use with this, (the cable is 5mm in diameter)
Blue Robotics has not tested tethers with fiber optic lines in them with WetLink penetrator glands, but it should work just fine! The only risk I can think of is damaging the fiber itself - the seal will compress the tether significantly, but I believe fibers are pretty strong in this type of loading. From what I understand, the danger comes from kinking a fiber tighter than its bend radius, which breaks the optical path. As long as this doesn’t happen (and it could post install in normal use without taking precautions) I think you’ll be all set!
We can’t say for certain, only a real-world test will really determine this! However I think that it will seal just fine - you haven’t shared a target depth you’ll be exposing the connection too?
Hi! Normally there is “gel” in the fiber optic tether that can be pushed into the pod if it is not pressure compensated. Often an oil filled pressure compensated junction box is used.
