4k Camera non-commanded servo tilt
Is anyone else having their 4k camera doing occasional un-commanded tilt ‘twitch’?
I have spent an awful lot of time bench testing my ROV with 4k camera, and have noticed that every so often the camera twitches, the tilt servo spasms, then returns to where it was. For transparency, I have had the tilt stabilization turned off from day 1.
Today while doing some bench tests, for other reasons, said tilt occurred at least twice - I did not catch the time of the first one to look at the logs, but the second time it occurred I was able to note the time and analyse both the Cockpit and .BIN logs. Both sets of logs confirmed that no cockpit or PWM signal was sent to the camera.
For more details on the ‘spasm’, it seems that the tilt servo fires, tilting the camera offsets setpoint, by maybe 10 degrees, then it returns to its set point.
Reference the Q1 PCB issue, this tilt twitch has occurred both before and since the solder clip.
Hi @3dMB -
We’ve noticed that same behavior on occasion, and don’t yet have a root cause. We do know that it happens on the hardware, and is not due to the autopilot sending a different PWM value. It’s a nuisance to be sure, and investigation is ongoing!
The camera does “jump” back from centering itself to the PWM value currently being commanded, so it hasn’t impacted use too much - it does seem like your setup is having the behavior crop up more than other situations have! Can you comment on the frequency it has been observed at?
It occurred once (that I noticed) over 3 dives yesterday. It just so happened that I was rolling at the time, so have it recorded https://youtu.be/-MZsQcuiJjU
