Currently out on a job, cannot get steady feed from camera. Using latest recommended version of Firmware, BlueOS and standalone Cockpit. Makes no difference if 4k, 1080, bitrate high or low. Exact perfect timed stalls as per pictures. Have swapped tethers, FXTIs, spool cables etc. no change.
And ideas, am currently swapping to different laptop but don’t think it will make any difference TBH.
Ok further investigation has resulted in the issue being better understood. We have had intermittent initialisation with the camera and the dropouts in the stream. I have connected directly to the switch and also bypassed the switch entirely and can see that the ethernet board on the camera is cycling on / off like clockwork every few seconds. It’s repeatable. We swapped a new 4k cam in and all working correctly again. It looks like the camera itself is ok but it’s network board is dying.
