Viable Power Option
I am currently looking at powering two T200 thrusters as well as a Thruster Commander and was hoping to use one power supply.
I have sourced a 1300MAH, 14.8V, 75C Lipo Battery,
(Hobbytech 1300mah 4S 14.8v 75C Lipo Battery XT60)
and by looking at the numbers, it has enough current to power the two thrusters,
1300mAh*75c = 97.5Amps
would this be a viable option?
Thanks in advance,
Hi Luke,
While the battery you linked would be capable of powering two T200 thrusters and a Thruster Commander, at full throttle it would only last around (1300 mAh)/(2 * 22000 mA per thruster)*(60 min/hour) = 2 minutes. For comparison, the batteries we sell on our shop have 18 Ah capacities, meaning they will last over ten times as long.
Also the Thruster Commander comes with a power cable for XT90 connectors (as opposed to the XT60 on the battery you linked), so you would need a different power cable to power the Thruster Commander with that battery.
-Daniel
Daniel,
Thank you for your quick response and info, and I appreciate your help
Okay,
So, I would just like to confirm, if the below power source will not blow up my T200 Thrusters, i really cannot afford that at the moment!
https://www.jaycar.com.au/medias/sys_master/images/9059483779102/MP3294-dataSheetMain.pdf
I appreciate your help.
Hi Luke,
The power supply has overload protection and should work fine! Won’t damage the thrusters as long as you choose one with an appropriate output voltage between 12-18v.
Rusty,
Thank you so much,
