Vacuum testing and the vacuum tester failures
(Julian Hancock) #1
Hi
The vacuum testers I use turn out to be a failures after a while. Can any one recommend a bullet proof version or another method of testing the seals.
Regards
Julian
(undersearobotics.com) #2
That was my experience with the brass pumps as well. I ended up getting a “mityvac” (made by Parker Hanifin) which seems better made and hasn’t had issues.
(Julian Hancock) #3
Hi Paul
Looking at their mityvac website is that their hand pumps?
Julian
#4
In Denmark/Sweden, this is available:
http://www.biltema.dk/da/Bil---MC/Varktoj-og-varkstedsudstyr/Testinstrument-og-Elektronik/Vakuumtesterbremseudluftningssat-2000022139/
(undersearobotics.com) #5
(Julian Hancock) #6
Wow that looks the business.
Julian
(Julian Hancock) #7
Thanks Paul, I shall have a look.
Julian
(Heinz) #8
I’ve had lots of luck with this one and it has a way to attach a tube to the valve that returns air that has been vacuumed out of the enclosure. I’m in Florida and humidity is a real problem and I return dry air into the ROV enclosure Vacum
(Julian Hancock) #9
Thanks Heinz.
(Joe) #10
We use the mighty vac as well. We once had some trouble finding an air leak. We rented (for free) a vacuum pump, used to do Air Conditioning work, from Autozone that drew a vacuum so quickly that we were actually able to hear the leak and find that we were getting air through a wire sheath from a leaking external camera. The electric vac also can remove all of the water from the container by boiling it off.
(Julian Hancock) #11
Thanks Joe
