UGPS not working, "no position from server" error
I am just starting to test the waterlink system.
on the waterlink page (http://192.168.2.2:2770/waterlinked), I get a “got no position from server” error.
After checking with waterlink, they said that it is probably because the “master-D1 top side doesn’t get depth data”.
How can I check whether the depth is correctly pushed to the waterlink board?
jean
I think you may be mixing up the webpages. You probably saw that error at the waterlinked address. Can you first verify that you see the Water LInked page at (http://192.168.2.94)?
If you see a webpage there, then the Water Linked system is running and connected to the ROV.
Then go to the ROV page http://192.168.2.2:2770/waterlinked and click the ‘start driver’ button. Make sure the ip/port entered is 192.168.2.94 / 80.
At this point the position should appear on the Waterlinked page (192.168.2.94).
sorry, yes, i did mix up the webpages…
  1. yes, i see a webpage at http://192.168.2.94 and have pushed the “start driver” button on the rov page http://192.168.2.2:2770/waterlinked
  2. after that, on the waterlink page http://192.168.2.94/#/acoustic , i still get “no position from server”
@jgk I’ve sent you a private message about this so we can get in touch directly.
