T200 on fishing SUP
#1
Hi!
I’d also like to mount T200 on my fishing SUP. I more like cruising time than speed. I would be satisfied with 2.5 mph, which is my average paddling speed.
Calculated hull speed is 4.9 knots (8.9 kmh). I have very flat bottom an and V shape nose.
Usually I’m 3-4 hours on the sea. With motor I would get more trolling capability and more distance.
I’m surprised, that this kayak has sped 2 mph with only 4 amps.
So, at first stage I’m planning one T200 and 30.000 mah 4S battery.
#2
I have a question about ESC. SUP has some specific demands. I don’t need reverse throttle. ESC wil be in a sealed box together with other electronic and batteries. Can I use ESC for a electric plane?
I must also use emergency kill switch with lanyard if I fall from SUP when motor is working.
For a speed control I’m planning to use High Precision Servo / ESC Tester for RC Model.
#3
I hope this topic will not be monologue. T200 is at home. I would like spend minimum necessary time for equipment assembly and disassembly. I will haveSUP fin for regular use, and second one with T200. I wiill try with this mounting:
T200%20akril
(Jacob) #4
An airplane ESC will be fine if you don’t need reverse. Where did you find a 30 Ah battery?
#5
Thank you Jacob. In Hobb… I’ll buy two 4S 16000 mAh Lipo packs. In parallel pack 2P4S that 32 Ah. In their Asian store they have even 20.000 mAh packs.
#6
And a few pics about what I’m talking about:
23826156
(Mark Langille) #7
Look at the new Thruster Commander, may make your project easier.
#8
Thank you Mark, I’ve seen new Commander.
I have another question. With T200 and Mounting Bracket we get four V shaped bolts. In custom or DIY projects usually V shape is not the best option.
Do you know where can we buy flat shaped bolts for saltwater environment? ? I suppose they are not metric also?
#9
I bought BlHeli V2 40 ESC. Please comment, if this settings are not ok.
#10
I’d like to use wireless remote control with Arduino. I’m waiting for a four button 433 MHZ. https://www.aliexpress.com/item/433MHz-RF-Transmitter-Receiver-Transmitter-Learning-Code-4-Channel-Module-Relay-Receiver-Module/32827010531.html
This is my first working code. I tested code on T200.
With:
button 1 - PWM increases 50 us every 0.35 sec (eight steps from neutral to full power)
button 2 - PWM decreases 50 us every 0.35 sec.
button 3 - PWM increases 100 us every 0.35 sec (four steps from neutral to full power)
button 3 - PWM is set to 1500 us (neutral)
all PWM signals are limited from 1100 to 1900 us.
BTW, 4-bit 7-segment display is working on Uno and not on Nano board. I do not know why.
#include <TM1637.h> //lib. for 7 seg. display
#include <Servo.h> //Using servo library to control ESC
Servo esc; //Creating a servo class with name as esc
#define CLK 3 //pins for display
#define DIO 4
TM1637 tm1637(CLK,DIO);
int PWM = 1500;
void setup(){
tm1637.init(); //reset display
tm1637.set(BRIGHT_TYPICAL);
delay(2000);
esc.attach(8); //Specify the esc signal pin,Here as D8
esc.writeMicroseconds(1500); //initialize the signal to 1500
// delay(2000);
Serial.begin(9600);
Serial.println(“Inicilizacija…”);
void loop(){
while (digitalRead(9) == LOW && digitalRead(10) && digitalRead(11) == LOW && digitalRead(12) == LOW) {
tm1637.display(3,0);
tm1637.clearDisplay();
while (digitalRead(9) == HIGH) {
tm1637.display(0,1);
PWM = PWM+50;
PWM = constrain(PWM, 1100, 1900);
Serial.println(PWM);
delay(350);
while (digitalRead(10) == HIGH) {
tm1637.display(1,2);
PWM = PWM-50;
delay(350);
while (digitalRead(11) == HIGH) {
tm1637.display(2,3);
PWM = PWM+100;
delay(350);
while (digitalRead(12) == HIGH) {
tm1637.display(3,4);
PWM = 1500;
delay(350);
esc.writeMicroseconds(PWM);
// Serial.println("Pulse Width Modelation ");
// Serial.println(PWM);
// delay(1000);
(Adam) #11
@e-sup
Your BlHeli settings are very close to what we have on the Basic ESC R3, but there are a couple changes I would recommend to get the thruster running as well as possible:
  • Turn off Low RPM Power Protect (fine for multirotors, can cause improper startup with underwater thrusters)
  • Turn Demag Compensation off (unnecessary to have on, reduces top end performance)
-Adam
