Sample code to run in QGC
Can you’ll provide a sample code and list of commands to send to Bluerov2 from mavlink command line in QGroundcontrol.
Hello, there is no ‘mavlink command line’ in QGroundControl.
You can check out MAVProxy and pymavlink. There are a lot of posts on this forum about these programs and what you can do with them
There is a mavlink console in qgroundcontrol
This console is a system shell for the operating system that ardupilot runs on. This shell doesn’t have anything to do with mavlink, the name is a little bit misleading. The data is passed back and forth between the OS and the QGC console via mavlink, but the association ends there.
