New Products! 6" Series and 8" Series Aluminum End Caps and 2" Series Tube
(Rusty) #1
Originally published at: http://www.bluerobotics.com/new-products-6-series-8-series-aluminum-end-caps/
Hole-y moley! We are pleased to announce the latest addition to the Watertight Enclosure Series: 6" Series and 8" Series Aluminum End Caps with more holes! We’re also excited to announce a new 2" Series Aluminum Tube with the greatest depth rating we’ve ever offered on an enclosure.
The 6" Series now has a 15-hole end cap option, and the 8" Series now has 15-hole and 25-hole options. These are perfect for projects where you need a lot of cable connections for a lot of sensors or other equipment. If you don't need all of the holes, you can use blank penetrators to fill them in. We think these new end cap options are pretty cap-tivating ;)
Next up is a 5.9", 150 mm Aluminum Tube for the 2" Enclosure Series. The tubes were successfully tested in the #Crushinator to 1000 m, which is the currently rated depth. However, they're designed to handle quite a bit more (potentially up to 2900m depth) but we don't have an easy way to test that. These new tubes are available as an option for the 2" Watertight Enclosure Series now!
That's it for today!
