lose the signal
(sergio Eslava) #1
Good afternoon, my name is Sergio, I just bought the Bluerov2, I have 2 questions.
because when I connect the ROV to my CPU (Macbook) after 10 minutes I lose the signal, to have a signal again, I have to disconnect the battery and connect it.
because the QGroun program does not let me install the Xbox360 control.
Could you give me some advice?
regards
(Jacob) #2
Hello, sorry we were not able to help you today. This is a strange problem that you describe. If you can please install Team Viewer, and contact support@bluerobotics.com to set up a time to meet remotely. This will be the fastest way to sort it out.
Have you installed the xbox controller driver as described in the “Joystick Setup” step in the software setup instructions?
