Lights on the ROV
(Julian Hancock) #1
Hi
I seem to have an issue with my LED lights now. Before I start pulling things to pieces I just wanted to make sure there was not an easy fix.
QGC shows the increase in the light level but its not reflected in the ROV as they are not coming on at all.
I have rebooted everything.
Addendum I have found it, a lose wire in the plug connecting to pixhawk.
Julian
(Jacob) #2
First make sure that you have the lights1 set up for channel 7 in the Vehicle Setup page. You should make sure that the red and black wires of the lights are connected to the power distribution terminals. You can test the lights functionality by jumping the yellow signal wire to battery+.
(Julian Hancock) #3
Thanks J
I have sorted it.
J
