Anyone had the issue of leak detector false alarm after replacing acylic tube to aluminum tube?
Leak detection msg poped out after a few minutes the ROV dived into water (15m deep). Seems to me it is the water drops condensated on the inner wall tube when the warm air inside the tube meets the cold wall of the tube (water temp around 4 celsius degrees @ 15 meters underwater).
@305155973, Yes you should try using the silica dessicant. It will remove the water from the air inside of the enclosure, and prevent condensation from forming.
Slightly different issue, but my QGC always registers a leak, so I’ve now deactivated it. I don’t think its the sensor because I get the same issue even with the board unpowered. I’ve followed the manual for pin assignment and logic. I’m using QGC 3.1.3. Any thoughts on the cause?
Is the LED turned on on the leak sensor board? If not, you definitely should not be registering a leak. If you can send a screen shot of your leak sensor setup screen that would be helpful.
Can you verify that the 3-wire cable from the leak sensor to the Pixhawk is connected in the right direction? And can you share a screenshot of the settings page?
