GPS connected to pixhawk in ArduSub
ardusub
#1
I believe I read that GPS is not supported in ArduSub, since GPS is not available under water. I would find it very use-full if GPS could be enabled. I would use it to document where I leave surface and where I re-surface.
Any help on this subject would be appreciated
(Kevin) #2
GPS is supported with ArduSub.
I’ve had it working on a Pixhawk 1 with the old 3DR GPS module and on a Pixhawk 2.1 with the HERE GPS. I haven’t tried the ones from mRobotics yet.
#3
Hi Kevin,
It works, just had to wait/move the GPS outside…
Now I just need to figure out how to show the position in QGroundcontrol…
(Kevin) #4
Ok great! It should show up automatically, unless you are asking for the specific lat/long…that hasn’t been implemented in the widget yet.
#5
My position is on the map, I was looking for the lat/long…
(Jacob) #6
Working on adding it right now!
#7
That is great :slight_smile:
Here you see the GPS
(Kevin) #8
Ok great, let us know how it works in the water at the surface positioned like that. I’ve tried a few orientations and couldn’t get anything to work. I was going to see if one of these would be a better fit: https://store.mrobotics.io/product-p/mro-ugps-samm8q-01.htm
#9
It works on the deck of the boat, but is not very stable in water…
(Kevin) #10
Yeah, we’ll need to figure out some sort of mast to mount it on outside the ROV. GPS signals just don’t penetrate water very far.
#11
After the latest software update, my GPS stopped working. The GPS is a BN-800 with a U-blox M8. Any idea what could have changed?
(Jacob) #12
What is the GPS_TYPE parameter set to? It should be ok if it is set to Auto.
#13
I tried Auto and U-blox, for GPS 1 in parameters
(Jacob) #14
What messages do you see in the mavlink inspector? Can you show what it says for GPS_RAW_INT, and GLOBAL_POSITION_INT?
#15
(Jacob) #16
You have GPS_TYPE set to ‘None’. It needs to be ‘Auto’.
#17
That was a mistake, but here you have mavlink inspector and GPS set to auto.
The GPS is connected to GPS - port on pixhawk
(Jacob) #18
Unplug the battery from the ROV, then plug it back in. Then click the message box next to the battery voltage at the top of the screen in QGC.
#19
Looks like this
(Jacob) #20
What do the SERIAL parameters look like?
