Hello
Has had big problems with mine GoPRO 3 black and 4 silver camera,have had only trouble with them.
Camera turns on and off all the time and Camera Freezes Up.
Sow yesterday i buy the new GoPRo 5 black, but camera can not output video from usb,only from hdmi.
If you are going to have video out you need a hdmi converter,shall return it to the store.
So now I’m tired of everything that matters GoPRO,Is not worth the money,in my opinion.
Have discovered a camera called FOXEER Box 4K CMOS.
This camera has USB video out and you can supply camera with 5 volt.
be mindful that they are small cameras, small heat sinks, and running them at high performance settings for long periods of time can cause them to overheat
if you are powering them externally, use a battery eliminator instead of via USB
I agree, very disappointing that AV out is not supported on the Hero 5.You could use the AuVidea B101 to actually connect the Hero 5 to the Pi via HDMI, but from what I’ve read it’s limited to 25FPS.
