Flight modes
Loaded everything and its moving along but I see the flight modes in QGroundControl are not listed as described. I see stabilized but no manual or depth hold. this is with QGroundconntrol 3.0 and simpleROV firmware with 4 ESC. is there a parameter I missed? FYI this is the Aug 3 build of firmware.
John
Are you using the “daily build” of qGround Control?
Hi John,
Please try the daily build of QGC, downloadable from the links here: http://ardusub.com/initial-setup/#install-qgroundcontrol
I believe I used the nightly builds but, I’ll remove and reinstall from the link
i must have gotten the wrong build. Grabbed the nightly today works fine. thanks
