Data string output
(Etienne Demers) #1
It would be good to have the sensors like depth, heading etc output from qgroundcontrol directly.
Should have an option to send to UDP and/or serial port and select which data to be included.
I know Jacob has come up with a backdoor solution but it is not obvious for those who are not used to the tools you are using for programming.
(Luis Gamez) #2
Yep Im agree with that! would be nice
(Jacob) #3
Can you provide a use case or two?
#4
I would use the data string for several purposes:
-Data string to external video overlay
-Data string to Survey Software
-Data string for logging purposes.
A string output would be very nice…
(Jacob) #5
These external applications will typically have a data format requirements. Is this the case, or am I free to push the data out however I see fit?
#6
May I suggest comma separated serial ASCII string with Carriage Return and line feed at the end. 9600 Baud and 1 Hz update?
The data sentence I consider must have:
Date, Time, Depth, Heading,
This is the nice to have:
Roll, Pitch, Latitude, Longitude, camera tilt,
Lat / Lon if available into system (surface GPS or "Underwater GPS)
Any comments @etienne ?
(Etienne Demers) #7
Sounds good to me.
Any string will do really. Most software will allow users to parse the string. I would maybe add an option for frequency. 1Hz can be a bit limiting.
I would also add altitude since this provision is already in the works…
Video overlay and connectivity with survey are the most common applications. But I would also use it to display these values outside QGC. IE make them BIGGER!! :grin:
(undersearobotics.com) #8
May I recommend using either an existing NMEA 0183 sentence or format the sentence(s) similar to NMEA 0183?
#9
It could be challenging to find an existing NMEA 0183 Sentence that will fit the various data fields to be included but a custom header in the string would be useful. For example:
$BROV, field1, field2, field3, etc
That will make sentence decoding even easier since it is a fixed field at the start of each line.
(Etienne Demers) #10
Most software detect the line feed and parse in between commas.
This is because most programming languages can fill a stringlist component with the comma as a delimiter automatically.
In the end, it really doesn’t matter as long as they provide something…
On my last survey I was unable to provide overlay because of this which was a bit of a let down.
