Can two dome end caps be bolted together?
I’m curious if two dome end caps can be bolted to each other to create a water tight spherical enclosure. Would an additional gasket be necessary?
Thank you
Hi Carl,
The O-ring seals are on the O-ring flanges, not on the dome, so you’d need an additional gasket or sealing surface to do this. That said, it should be very possible to that.
